22 years agoProblems launching Nios II ISS
Launching the Nios II ISS generates the following error message: Error! : Unable to load memory block at address 0x20 from ELF file Release/nios_program.elf Fatal Error! : Memory map is not c...
22 years agoI managed to find the solution for this problem.
In SOPC Builder, under the Nios II sub-menu ('More "cpu" Settings'): Changing the Exception Address from using the flash memory to SDRAM made ISS run properly. Apparently, using the flash memory for the exception address is illegal behaviour..
