15 years agoProblems debugging simple program in NIOS II IDE
Hardware and software tools: NIOS II IDE 10.1 ("Legacy") Quartus II 10.1 Device:Arria II GX - EP2AGX260FF35I5N I am using software tools and hardware as described and a custom board.When ...
15 years agowell here are the messages:
Build message: **** Build of configuration Debug for project hello_world_after_license **** make -s all includes Compiling hello_world.c... ../hello_world.c: In function `main': ../hello_world.c:21: warning: unused variable `g' Linking hello_world_after_license.elf... Info: (hello_world_after_license.elf) 55 KBytes program size (code + initialized data). Info: 1992 KBytes free for stack + heap. Hardware simulation is not enabled for the target SOPC Builder system. Skipping creation of hardware simulation model contents and simulation symbol files. (Note: This does not affect the instruction set simulator.) Build completed in 1.89 seconds Nios II Download output: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x002010B0: verified Initializing CPU cache (if present) OK Nios II terminal window: nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Nios II gdb-server-output: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x002010B0: verified Listening on port 4262 for connection from GDB: 59saccepted Exiting due to 'k' command from GDB Leaving target processor paused Nios II -elf-gdb: mi_cmd_stack_list_frames: No stack. No symbol "new" in current context. kill
