20 years ago
problem with using elf2flash!!!
my vmlinux is only 1.3M Bytes
when i use:
elf2flash --base=0x0 --end=0x3fffff --reset=0x0 --input=vmlinux --output=ext_flash.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec
i get the ext_flash.flash with the size of 3.6M Bytes, why the final file became so big, is the boot copier takes up 2.3M bytes?
i think the boot loader is no more then 500k bytes , why the .flash file became so big?
    --- Quote Start ---
    originally posted by leadensky@Aug 22 2006, 02:30 AM
    my vmlinux is only 1.3m bytes
    when i use:
    elf2flash --base=0x0 --end=0x3fffff --reset=0x0 --input=vmlinux --output=ext_flash.flash --boot=$sopc_kit_nios2/components/altera_nios2/boot_loader_cfi.srec
    i get the ext_flash.flash with the size of 3.6m bytes, why the final file became so big, is the boot copier takes up 2.3m bytes?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17753)
    --- quote end ---
    --- Quote End ---
    the .flash-File is a Ascii-Hex File. One Byte is coded in more bytes....
    Marco
    --- Quote Start ---
    originally posted by mabcom@Aug 22 2006, 03:41 PM
    hi,
    the .flash-file is a ascii-hex file. one byte is coded in more bytes....
    marco
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17754)
    --- quote end ---
    --- Quote End ---
    Thank you
    i have read the data in the flash, the actual playload is less than 1.4M bytes, so if i use a flash with the size of 2M, it will work with no problem when i use: nios2-flash-programmer --base=0 ext_flash.flash, with the 3.5M bytes ext_flash.flash file ?
