20 years agoproblem with usb driver
hi, I have boot uclinux kernel successful,then i plug a usb disk on my board,that's ok.But it show errors when i run the follow code: [/CODE]fdisk -l /dev/sda fdisk:Bad command or file name [...
20 years agoHi,hippo. I have solved the usb problem by enable fdisk in busybox. Now,I want to programme my apps by using the device driver,how can i do? Which files should i include? Thahk you! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
