20 years agoproblem with usb camera
Hi, I have some trouble with getting usb camera to work. I configured kernel with UsbHost following the document in http://nioswiki.jot.com//wikihome/operatingsystems/usbhost (http://nioswiki.j...
19 years agoLeewood,
sorry for late reply. I had been very busy. I did not know isp1362 well. I am better on isp1761. They should be similar. You are right. It is possible to use isp1362 for isochronous transfer. Most of the code are there. There might be some bugs. You may look at the other chipset to find out how they work for iso. You can find out the error from the source. I think NPX (philips semi) have the driver. Maybe you can check with them. Hippo
