15 years agoProblem with UBIFS (NOR flash) in uClinux
I'm trying use UBIFS in my board because I had problem with JFFS2, after some writes in JFFS2 I can't write anymore and shows a message: MTD do_write_oneword(): software timeout MTD do_write_oneword(): software timeout MTD do_write_oneword(): software timeout MTD do_write_oneword(): software timeout Write of 188 bytes at 0x005fc078 failed. returned -5, retlen 0 Not marking the space at 0x005fc078 as dirty because the flash driver returned o Because this problem I'm trying UBIFS. I use a NOR FLASH with 8MB (S29JL064H) and uClinux kernel 2.30 In the kernel is enabled config.c (Flash partitions) { .name = "romfs", .size = 0x600000, .offset = 0x200000, }, { .name = "loader/kernel", .size = 0x200000, .offset = 0, } --- Memory Technology Device (MTD) support [ ] Debugging < > MTD concatenating support [*] MTD partitioning support <*> Enable UBI (4096) UBI wear-leveling threshold And in Miscellaneous filesystems <*> UBIFS file system support In the kernel boot : (rootfstype=ubifs ubi.mtd=0 root=ubi0:rootfs) Default kernel command For create a ubifs image I used cat ubinize.cfg [ubifs] mode=ubi image=ubifs.img vol_id=0 vol_size=4MiB vol_type=dynamic vol_name=rootfs vol_alignment=1 vol_flags=autoresize mkfs.ubifs -d romfs -m 1 -e 65408 -c 128 -o ubifs.img -D device_table.txt ubinize -o ubi.img -m 1 -p 64KiB -v ubinize.cfg Everthing is allrigth , to create a .flash I use the commands bin2flash --input=ubi.img --location=0x200000 --output=ubi.flash nios2-flash-programmer --base=0x2000000 --erase-all (format flash) nios2-flash-programmer --base=0x2000000 ubi.flash After this I tried boot with my kernel nios2-download -g zImage After the boot I have a kernel panic uClinux/Nios II Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032 Kernel command line: rootfstype=ubifs ubi.mtd=0 root=ubi0:rootfs NR_IRQS:32 PID hash table entries: 32 (order: 5, 128 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5804k/2107k RAM, 0k/0k ROM (1747k kernel code, 360k data) Calibrating delay loop... 63.89 BogoMIPS (lpj=319488) Mount-cache hash table entries: 512 net_namespace: 264 bytes NET: Registered protocol family 16 init_BSP(): registering device resources bio: create slab <bio-0> at 0 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered NET: Registered protocol family 1 io scheduler noop registered io scheduler deadline registered (default) ttyS0 at MMIO 0x2810000 (irq = 3) is a Altera UART console [ttyS0] enabled ttyS1 at MMIO 0x2810060 (irq = 4) is a Altera UART IIPDEV Driver Initialized SYSDEV Driver Initialized TXTABLEDEV Driver Initialized RXTABLEDEV Driver Initialized ALARMDEV Driver Initialized smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <[email protected]> eth0: SMC91C11xFD (rev 2) at 82800300 IRQ 2 [nowait] eth0: Ethernet addr: 00:11:22:33:44:55 physmap platform flash device: 00800000 at 02000000 physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 physmap-flash.0: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using physmap partition information Creating 2 MTD partitions on "physmap-flash.0": 0x000000200000-0x000000800000 : "romfs" 0x000000000000-0x000000200000 : "loader/kernel" UBI: attaching mtd0 to ubi0 UBI: physical eraseblock size: 65536 bytes (64 KiB) UBI: logical eraseblock size: 65408 bytes UBI: smallest flash I/O unit: 1 UBI: VID header offset: 64 (aligned 64) UBI: data offset: 128 UBI: volume 0 ("rootfs") re-sized from 65 to 92 LEBs UBI: attached mtd0 to ubi0 UBI: MTD device name: "romfs" UBI: MTD device size: 6 MiB UBI: number of good PEBs: 96 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 96 UBI: number of PEBs reserved for bad PEB handling: 0 UBI: max/mean erase counter: 1/0 UBI: background thread "ubi_bgt0d" started, PID 20 m25p80 spi0.0: m25p16 (2048 Kbytes) Creating 1 MTD partitions on "m25p80": 0x000000000000-0x000000200000 : "fpga configuration" i2c /dev entries driver i2c-0: I2C OpenCores Bus Adapter, MMIO = 0x20, irq = 0 i2c-0: Using 16003kHz clock source TCP cubic registered NET: Registered protocol family 17 UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x914d95fa, read 0x3c UBIFS error (pid 1): ubifs_check_node: bad node at LEB 0:0 UBIFS error (pid 1): ubifs_read_node: expected node type 6 VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) Someone have some ideia? Thanks, Caio PereiraNo RepliesBe the first to reply
