20 years agoproblem with the stand alone LWIP
Hello all, I downloaded the stand alone Lwip from the following link: http://forum.niosforum.com/forum/index.php?showtopic=949 (http://forum.niosforum.com/forum/index.php?showtopic=949) ...
20 years agoHi All,
Lwip standalone version can run in Nios2 IDE6.0. following is my stage for reference. 1. unzip lwip-v1.1.zip 2. copy sopc_builder/components/altera_avalon_lan91c111 to kits/nios2_60/components 3. use setup.exe to install package into kits/nios2_60/components 4. move kits/nios2_60/components/altera_avalon_lan91c111 to sopc_builder/components 5. Use IDE to create a blank application project and move all files from lwip_web_server folder to the blank application project 6. remove .cdtbuild and added the four build paths as described in the readme file from c/c++ build of application project. 7. then, compile the project. 8. IDE will respond a lot of error as following in system library. Regards
