21 years agoProblem with the new Quartus 4.2/Nios2 update
Hello, I just updated the Quartus 4.2. I used the vga streaming example. Compiled the sopc block new, synthesized the whole project again and when I use a simple hello world example the comp...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I upgraded to Quartus4.2 and now also to NiosII 1.01[/b] --- Quote End --- <div class='quotetop'>QUOTE </div> --- Quote Start --- error: `ALT_DMA_SET_MODE_128' undeclared (first use in this function)[/cygdrive/c/altera/quartus42/sopc_builder/components/altera_avalon_dma/HAL/src/altera_avalon_dma.c][/b] --- Quote End --- If that may be of use: I have the exact same error message with this combination of tools: I did not upgrade to niosII 1.1. Only went from quartus 4.1sp2 to quartus4.2, and this error showed up. Actually I noticed that the error pointed to the file altera_avalon_dma.c in the quartus2 directory and not to the file with the same name in the niosII kits folders. This scared me off to remove q4.2 again as I was suspecting installation problems and instead await Nios forums experience with the new release. I did not find any way to tweek library paths, and probably good so. Maybe installing both Q4.2 AND niosII1.1 will solve this? But has the library moved in the new releases?
