21 years agoProblem with the new Nios II 1.1 release
Hello, Altera has released Nios II 1.1 for Quartus II 4.2. I downloaded the evaluation version and installed it. After generating the new system in SOPC Builder and synthesizing the system in Q...
21 years agoAll,
Do any of you have an archived copy of your pre-quartus-4.2 design somewhere? If so, can you carefully examine the top-level SOPC-Builder-generated module and look at the address bus(es) going to your external peripherals please (in comparison to the one that was just generated and doesn't function)? The reason I ask: there was a change in Quartus II 4.2 (SOPC Builder) -- a bug fix in how address busses are generated -- that may *remove* a top-order address pin in interfaces to certain external busses. So for example, you may have previously had A[6..0] popping out the top and now have A[5..0]. As you can imagine this can be a problem if software was written to use this address pin, or depending on how the A[] bus is hooked up to the outside world in your top-level HDL or schematic capture. We are working on posting a detailed explanation of this problem and workarounds to the Altera website at the moment -- this *may* not even be the problem you're seeing in your system, but it sounds awfully familiar. I'd type out a long-winded explanation this second but I am hoping to have a web-link that I can paste here shortly. EDIT: what I say above applies for the symptoms niosIIuser is reporting. What MiR was seeing was something different, based on the new 'Component Builder' - that is a separate discussion but one that should not require going back to Nios II 1.01 to solve.
