15 years agoProblem with the baud rate
I'm studying NiosII these days, and I'm confused with the baud rate of the UART. In the Altera's user guide, the relation among baud rate, frequency and divisor is given by divisor=int(frequency...
15 years agoSince frequency/baud_rate is generally a non integer number but divisor must be integer, the +0.5 trick gives you the best approximation of the required baud rate: i.e if decimal part <0.5 approximates to lower integer, while if >=0.5 approximates to upper one.
