20 years agoProblem with TCM
Hi everybody,
I begin descibing our system: Quartus 5.01 NIOS II 5.01 64K TCM Instruction(Dual port memory--> 1 for I master and 1 for avalon data) Base address --> 0x02300000 32K TCM Data Base address --> 0x02310000 SDRAM Base adress --> 0x01000000 ext_ram Base adress --> 0x02000000 ext_flash Base address --> 0x00000000 SOPC Settings: Reset address --> flash Exception address --> Instruction TCM/s1, offset 20 --> address: 0x02300020 IDE settings: .text --> Instruction TCM/s1 .rodata, .rwdata... --> DataTCM The linker gives the next error: section .text [02300020 -> 02305F83] overlaps section .exception [02300020 -> 0230001C7]. This error doesn't happen when both sections are located in SDRAM(this is the way we have it before using TCM). So to me it seems that if the sections are in SDRAM the linker knows how to locate them in order not to overlap. But if I put the two sections in a TCM the linker can not locate them. Is this a bug?? What´s the problem? Thanks in advance, LuisNo RepliesBe the first to reply
