19 years agoProblem with ssram
Hello Everyboby. I'am a beginers so every information will be helpful for me. My problem is associate with ssram placed on the nios development board cyclon II edition ep2c35. 1) I have seen...
15 years ago --- Quote Start --- Hi again. Success!!! . My friend (leszekd) found solution. As BadOmen wrote it was problem witch timing settings, but it is little bit more complicate. You have to open file which has got extension QSF and paste there under the ssram fitter assignments ssram timing and current_strength setings. # Dropping ssram drive strength# ------------------------- set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to data_to_and_from_the_ext_ssram set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to address_to_the_ext_ssram set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to adsc_n_to_the_ext_ssram set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to bw_n_to_the_ext_ssram set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to chipenable1_n_to_the_ext_ssram set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to outputenable_n_to_the_ext_ssram set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to bwe_n_to_the_ext_ssram set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to ssram_adsp_n set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to ssram_adv_n set_instance_assignment -name CURRENT_STRENGTH_NEW 12MA -to sram_clk set_instance_assignment -name TCO_REQUIREMENT "3.3 ns" -from * -to adsc_n_to_the_ext_ssram set_instance_assignment -name TCO_REQUIREMENT "3.3 ns" -from * -to bwe_n_to_the_ext_ssram set_instance_assignment -name TCO_REQUIREMENT "3.3 ns" -from * -to chipenable1_n_to_the_ext_ssram set_instance_assignment -name TCO_REQUIREMENT "3.3 ns" -from * -to data_to_and_from_the_ext_ssram set_instance_assignment -name TSU_REQUIREMENT "6 ns" -from * -to data_to_and_from_the_ext_ssram set_instance_assignment -name TCO_REQUIREMENT "3.3 ns" -from * -to outputenable_n_to_the_ext_ssram set_instance_assignment -name TCO_REQUIREMENT "3.3 ns" -from * -to address_to_the_ext_ssram set_instance_assignment -name TCO_REQUIREMENT "3.3 ns" -from * -to bw_n_to_the_ext_ssram set_global_assignment -name RESERVE_ALL_UNUSED_PINS_NO_OUTPUT_GND "AS INPUT TRI-STATED" set_instance_assignment -name PARTITION_HIERARCHY no_file_for_top_partition -to | -section_id Top Many thanks for you all. See you again Marcin --- Quote End --- Hi I also have a problem with the SSRAM. What did you mean with "under the ssram fitter assignments ssram timing and current_strength setings." Where do I have to paste the file?
