21 years agoProblem with setting size of filesystem
Hi I am having a little problem with my filesystem. When I create a filesystem project I can put in a maximum of 1024k. How can I change this to 2048k or more??? Regards Michael E
20 years agoHi Ken!
I have only set memory map in altera.c under CONFIG_ALTERA_STRATIX_II, because it's for a Stratix II. And when I changed the kernel size I also change offset of filesystem in the belonging STF file. But there is only 220 KB free space and I didn't getting this information by a warning. If reach this limit when I try to generate a file greater then 220 KB. Could it be that I have to set something other in some C-files to enlarge the size of the filesystem? Bye, Lothar.
