21 years agoProblem with setting size of filesystem
Hi I am having a little problem with my filesystem. When I create a filesystem project I can put in a maximum of 1024k. How can I change this to 2048k or more??? Regards Michael E
20 years ago --- Quote Start --- originally posted by maico@Sep 30 2005, 04:15 AM hello all!
i've changed in altera.c the definition of memory mapping in several ways.
i've done it only at definition of config_altera_stratix_ii, because it's only for a stratix ii.
but free space in filesystem leave the same: 220 kb
do i have to change other files then altera.c and the stf-file of filesystem
to get more free space?
bye, lothar.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10063)
--- quote end ---
--- Quote End --- If your maps and STF file are setup properly, then don't worry about the amount of free space that the filesystem project reports. It's only a warning based on what it can find in the system PTF. That warning will not prevent you from making a filesystem larger than 220kb.
