21 years agoProblem with setting size of filesystem
Hi I am having a little problem with my filesystem. When I create a filesystem project I can put in a maximum of 1024k. How can I change this to 2048k or more??? Regards Michael E
20 years agoHi Lothar
I changed the parameters in the altera.c file since I am using an Altera Cyclone2 EP2C35 dev board. I defined it in the kernel configuration part as a CONFIG_ALTERA_STRATIX_II cpu (mainly for the similarity in functionality). So I changed the CONFIG_ALTERA_STRATIX_II defines in the .c file. No my question is where do I tell Nios II IDE that the kernel is not 2MB but 3MB without having to edit the 'project_name'.stf file for each file system project?? --This works fine for now, but is there a better way of "defining" this. Thanks Rual
