19 years agoProblem With Reset,Exception Address Offset
I am lerning how to make new custom logic component and tryed LED_PIO example which is in example designs for Development bords. So I made new Quartus project and made New component with Test_...
19 years agoif you get <div class='quotetop'>QUOTE </div>
--- Quote Start --- cpu_o instruction cace must be smaller then the instruction-master address space[/b] --- Quote End --- than your project is probly missing some memory component for instructions, or you have it but is not connected to the instruction bus. You may add a small internal memory segment (16kB) and change the CPU for the small one so it will not consume M4K blocks for cache. IzI
