11 years agoProblem with Pin out not corresponding to the settings in my design
I am usign Quartus II to program an FPGA Cyclone 3. I am including the Nios Processor in my design. I had it working initially satisfactorily. However, I made a few additions and modifications ...
11 years ago --- Quote Start --- Did you check fpga pin assignments? You can also try Signaltapping the pio output or loopback it to a pio input. --- Quote End --- Cris72, Thanks for the advice. I did signal tapping (looping the output to an input) and things were fine. However, after a careful checking of the FPGA pin assignments I noticed I had assigned one pin wrongly. I fixed it and my problem is solved now.
