20 years agoproblem with NiosII IIS
I add a IP core(from Mentor Graphics) to SOPC . The Nios II ISS generates the following warning message when I try to run it:
warning : sopc builder system component mentor_inventra_avalon_10_100_ethernet_mac_0 is not supported by the simulator. simulation may be incorrect if your soft
ware attempts to access it
ac_1 is not supported by the simulator. simulation may be incorrect if your soft
ware attempts to access it I've been hearded that iss supports simulation of the following peripherals: . memory (ram/rom) . avalon timer . avalon jtag uart . avalon uart Accesses to unsupported peripherals will be ignored. How can I solve this problem? Or, I should choose another way to begin writing and debugging Nios II applications before the final hardware configuration is determined? Thanks!
