Daniel__Liu
3 years agoProblem with "New - Nios II Application and BSP from template".
The problem happened when I wanted to create "New - Nios II Application and BSP from template". My Quartus is 21.2 pro. I reinstalled WSL 1 and Ubuntu 18.04 LTS. But it still happened.
Dos ...
ShengN_altera
3 years agoHi,
I would suggest that uninstalling and reinstalling the whole Quartus and Eclipse IDE as may be the problem is on Quartus but not on Eclipse IDE. After reinstalling, I'm sure that the broken or corrupted software files will be fixed if there are and environment variable will be set correctly by Quartus itself. Or you can try out the virtual machine.
As I totally don't know which software you're installing before.
Sheng
