13 years agoproblem with mutex core
Dear all, I've created a qsys system composed of two NIOS, each one attached to its on-chip memory that contains its program. the two processors are connected to a shared RAM protected via a ...
13 years agoThe SignalTap section of the Quartus manual is well written: http://www.altera.com/literature/hb/qts/qts_qii53009.pdf
You will need to find the control signals to your memory block, and monitor the address, read, write, read_data and write_data signals. Then you can trigger on either the read or the write signal to see what is happening.
