20 years agoProblem with mount rootfs
When I download the sof and zImage file to the target board. Then typed "nios2-termial" in the niosSDK command. But I can't boot the uclinux. The error message is "kernel pant...
20 years ago --- Quote Start --- originally posted by hippo@Jul 21 2006, 01:51 AM do you use initramfs? the initramfs may be incorrect or /init missing.
look at usr/initramfs_list in kernel dir.
do you use kernel command line string? it should be blank.
have you tried the prebuilt zimage?
http://nioswiki.jot.com/wikihome/operating...x/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/tryoutuclinux)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17051)
--- quote end ---
--- Quote End --- Thanks. I boot the uclinux on the target board sucessfully. I think the cause is that I forgot type the commnn "make romfs".
