20 years agoproblem with modules
I follow http://nioswiki.jot.com/wikihome/operating...duleprogarmming (http://nioswiki.jot.com/wikihome/operatingsystems/moduleprogarmming) but when I type in "modprobe hello" what I get is "modprobe...
20 years ago --- Quote Start --- originally posted by miked@Jul 21 2006, 02:43 AM anyway, i believe the reason module loading is failing is because of the ramfs_nommu_mmap function being a stub (see linux-2.6.x/fs/ramfs/file-nommu.c)...
int ramfs_nommu_mmap(struct file *file, struct vm_area_struct *vma)
return 0;
shouldn't this be setting vma->vm_start to something at least?
if your modules reside somewhere other than ramfs, everything seems to work ok. try loading your modules from a filesystem on a cf card or something...
mike
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17040)</div> --- Quote End --- I had the same problem when boa was serving files from ramfs using mmap. Looks like it is fixed in kernel version 2.6.18. ramfs_nommu_mmap now looks like this:
return vma->vm_flags & VM_SHARED ? 0 : -ENOSYS;
} I changed this in my kernel version 2.6.16 and now my boa problem was gone. Hein
