20 years agoproblem with modules
I follow http://nioswiki.jot.com/wikihome/operating...duleprogarmming (http://nioswiki.jot.com/wikihome/operatingsystems/moduleprogarmming) but when I type in "modprobe hello" what I get is "modprobe...
20 years agoinsmod: cannot insert `/lib/modules/2.6.16-uc0/kernel/drivers/misc/hello.ko': Invalid module format (-1): Exec format error
modprobe: failed to load module hello I have the same problem! If you comment out the whole if (vma->vm_file) {} block in do_mmap_private(), then the function will make a private copy and modules seem to insert ok. In my linux-2.6.x/mm/nommu.c file there seems not to be any do_mmap_private function... :-( Anyway... is a little strange that the error could be in the nommu.c, isn't it? Because if it were, it should fail to everybody... I think. I have a question regarding the Makefile posted by wgoosens. I've tried to compile a module with this makefile, but it seems to me that there is something missing in it, because when I try to run make, it says <div class='quotetop'>QUOTE </div> --- Quote Start --- make -k all make: Nothing to be done for `all'.[/b] --- Quote End --- Maybe it's very simple, but I don't know what to add. To my eyes, it seems that I should add the objects to be compiled, for example, but I don't exactly how to do it. What am I missing? Thank you AleX
