20 years ago
Problem with libpng
I compiled the kernel with building libpng (Kernel/library/defaul tselection->Customize Vendor /User Settings->Library Configuration->Build libpng).I have selected Building libZ which was needed by libpng.
But it failed.the error as follow:
make[2]: Entering directory `/home/leewood/uClinux-dist-test/include'
find . -depth -type l -a ! -name Makefile | xargs rm > /dev/null 2>&1 || exit 0
find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0
Making symlinks in include/
Making include/c++ symlink to compiler c++ includes
make[2]: Leaving directory `/home/leewood/uClinux-dist-test/include'
make[2]: Entering directory `/home/leewood/uClinux-dist-test/lib'
Making symlinks in lib/
make[2]: Leaving directory `/home/leewood/uClinux-dist-test/lib'
make[2]: Entering directory `/home/leewood/uClinux-dist-test/lib/zlib'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/leewood/uClinux-dist-test/lib/zlib'
make[2]: Entering directory `/home/leewood/uClinux-dist-test/lib/libpng'
nios2-linux-uclibc-gcc -shared -Wl,-soname,libpng.so.2 -o libpng.so.2.1.0.12
png.pic.o pngset.pic.o pngget.pic.o pngrutil.pic.o pngtrans.pic.o pngwutil.pic.o pngread.pic.o pngrio.pic.o pngwio.pic.o pngwrite.pic.o pngrtran.pic.o pngwtran.pic.o pngmem.pic.o pngerror.pic.o pngpread.pic.o -L../zlib -lz -lm -lc
nios2-linux-uclibc-gcc: unrecognized option `-shared'
/opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/crt1.o(.text+0x10): In function `_start':
: undefined reference to `main'
/opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/crt1.o(.text+0x14): In function `_start':
collect2: ld returned 1 exit status
make[2]: *** [libpng.so.2.1.0.12] 错误 1
make[2]: Leaving directory `/home/leewood/uClinux-dist-test/lib/libpng'
make[1]: *** [all] 错误 2
make[1]: Leaving directory `/home/leewood/uClinux-dist-test/lib'
make: *** [subdirs] 错误 1
[leewood@localhost uClinux-dist-test]$
Pls help.Thanks!
    --- Quote Start ---
    originally posted by leewood@Jul 31 2006, 02:27 AM
    hi,
    i compiled the kernel with building libpng (kernel/library/defaul tselection->customize vendor /user settings->library configuration->build libpng).i have selected building libz which was needed by libpng.
    but it failed.the error as follow:
    make[2]: entering directory `/home/leewood/uclinux-dist-test/include'
    find . -depth -type l -a ! -name makefile | xargs rm > /dev/null 2>&1 || exit 0
    making symlinks in include/
    making include/c++ symlink to compiler c++ includes
    make[2]: leaving directory `/home/leewood/uclinux-dist-test/include'
    make[2]: entering directory `/home/leewood/uclinux-dist-test/lib'
    making symlinks in lib/
    make[2]: leaving directory `/home/leewood/uclinux-dist-test/lib'
    make[2]: entering directory `/home/leewood/uclinux-dist-test/lib/zlib'
    make[2]: nothing to be done for `all'.
    make[2]: leaving directory `/home/leewood/uclinux-dist-test/lib/zlib'
    make[2]: entering directory `/home/leewood/uclinux-dist-test/lib/libpng'
    nios2-linux-uclibc-gcc -shared -wl,-soname,libpng.so.2 -o libpng.so.2.1.0.12
    png.pic.o pngset.pic.o pngget.pic.o pngrutil.pic.o pngtrans.pic.o pngwutil.pic.o pngread.pic.o pngrio.pic.o pngwio.pic.o pngwrite.pic.o pngrtran.pic.o pngwtran.pic.o pngmem.pic.o pngerror.pic.o pngpread.pic.o -l../zlib -lz -lm -lc
    /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/crt1.o(.text+0x10): in function `_start':
    /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/crt1.o(.text+0x14): in function `_start':
    make[2]: leaving directory `/home/leewood/uclinux-dist-test/lib/libpng'
    make[1]: leaving directory `/home/leewood/uclinux-dist-test/lib'
    [leewood@localhost uclinux-dist-test]$
    pls help.thanks!
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17277)
    --- quote end ---
    --- Quote End ---
    hi leewood,
    You might have solved problem by your self, but if not, then here is the reason......
    nios2-linux-uclibc-gcc: unrecognized option `-shared&#39;
    nios2-linux-uclibc-gcc does not compile shared libraries, you need to compile libpng lib as static.
    nios2-linux-uclibc-gcc will not take "-g", "-shared" options.
    What you need to do is ..... in configure script either give "static" option or either remove "-shared" from your all Makefiles.
    Do remember to make distclean your code : ).
    thanks,
    Ankur
    Hi, Ankur
    I have done what you told me......"in configure script either give "static" option or either remove "-shared" from your all Makefiles."
    But the result is
    make[2]: Entering directory `/home/leewood/uClinux-dist-test/lib/libpng&#39;
    nios2-linux-uclibc-gcc -static -Wl,-soname,libpng.so.2 -o libpng.so.2.1.0.12
    png.pic.o pngset.pic.o pngget.pic.o pngrutil.pic.o pngtrans.pic.o pngwutil.pic. o pngread.pic.o pngrio.pic.o pngwio.pic.o pngwrite.pic.o pngrtran.pic.o pngwtran .pic.o pngmem.pic.o pngerror.pic.o pngpread.pic.o -L../zlib -lz -lm -lc
    /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/c rt1.o(.text+0x10): In function `_start&#39;:
    : undefined reference to `main&#39;
    /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/c rt1.o(.text+0x14): In function `_start&#39;:
    make[2]: *** [libpng.so.2.1.0.12] &#38169;&#35823; 1
    make[2]: Leaving directory `/home/leewood/uClinux-dist-test/lib/libpng&#39;
    make[1]: *** [all] &#38169;&#35823; 2
    make[1]: Leaving directory `/home/leewood/uClinux-dist-test/lib&#39;
    make: *** [subdirs] &#38169;&#35823; 1
    In fact,I want to add the application "vidcat" (Miscellaneous Application->Video tools->vidcat) into my kernel. It needs libz,libpng and libjpeg builded before. The libz and libjpeg have been builded, but libpng always failed.
    Pls help.Thanks!
    --- Quote Start ---
    originally posted by leewood@Jul 31 2006, 05:16 PM
    in fact,i want to add the application "vidcat" (miscellaneous application->video tools->vidcat) into my kernel. it needs libz,libpng and libjpeg builded before. the libz and libjpeg have been builded, but libpng always failed.
    pls help.thanks!
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17296)
    --- quote end ---
    --- Quote End ---
    Take a look at your two successful library builds and find out what command was used to create the static library. (something like libpng.a)
    Also, it&#39;s pretty likely that the libpng makefile already knows how to build the archive library (.a extension) as that is a typical build target on systems that are capable of building and using shared libraries.
    Cheers,
    - slacker
    Hi,slacker
    I do not understand...."it&#39;s pretty likely that the libpng makefile already knows how to build the archive library (.a extension) as that is a typical build target on systems that are capable of building and using shared libraries."
    So I paste the Makefile as follow:
    # makefile for libpng on Linux ELF with gcc# Copyright © 1998, 1999 Greg Roelofs# Copyright © 1996, 1997 Andreas Dilger# For conditions of distribution and use, see copyright notice in png.h
    # CC=gcc
    # where "make install" puts libpng.a, libpng.so*, png.h and pngconf.h
    prefix=/usr/local
    # Where the zlib library and include files are located# ZLIBLIB=/usr/local/lib# ZLIBINC=/usr/local/include
    ZLIBLIB=../zlib
    ZLIBINC=../zlib
    ALIGN=# for i386:# ALIGN=-malign-loops=2 -malign-functions=2
    WARNMORE=-Wwrite-strings -Wpointer-arith -Wshadow
    -Wmissing-declarations -Wtraditional -Wcast-align
    -Wstrict-prototypes -Wmissing-prototypes# -Wconversion
    # for pgcc version 2.95.1, -O3 is buggy; don&#39;t use it.
    CFLAGS += -I$(ZLIBINC) -Wall -O3 -funroll-loops
    $(ALIGN)# $(WARNMORE) -g -DPNG_DEBUG=5# LDFLAGS=-L. -Wl,-rpath,. -L$(ZLIBLIB) -Wl,-rpath,$(ZLIBLIB) -lpng -lz -lm
    # RANLIB=ranlib# RANLIB=echo
    # read libpng.txt or png.h to see why PNGMAJ is 2. You should not# have to change it.
    PNGMAJ = 2
    PNGMIN = 1.0.12
    PNGVER = $(PNGMAJ).$(PNGMIN)
    INCPATH=$(prefix)/include
    LIBPATH=$(prefix)/lib
    OBJS = png.o pngset.o pngget.o pngrutil.o pngtrans.o pngwutil.o
    pngread.o pngrio.o pngwio.o pngwrite.o pngrtran.o
    pngwtran.o pngmem.o pngerror.o pngpread.o
    OBJSDLL = $(OBJS:.o=.pic.o)
    .SUFFIXES: .c .o .pic.o
    .c.pic.o:
    $(CC) -c $(CFLAGS) -fPIC -o $@ $*.c
    # all: libpng.a libpng.so pngtest
    libpng.a: $(OBJS)
    ar rc $@ $(OBJS)
    $(RANLIB) $@
    libpng.so: libpng.so.$(PNGMAJ)
    ln -sf libpng.so.$(PNGMAJ) libpng.so
    libpng.so.$(PNGMAJ): libpng.so.$(PNGVER)
    ln -sf libpng.so.$(PNGVER) libpng.so.$(PNGMAJ)
    libpng.so.$(PNGVER): $(OBJSDLL)
    $(CC) -Wl,-soname,libpng.so.$(PNGMAJ) -o libpng.so.$(PNGVER)
    $(OBJSDLL) -L$(ZLIBLIB) -lz -lm -lc
    pngtest: pngtest.o libpng.so
    $(CC) -o pngtest $(CFLAGS) pngtest.o $(LDFLAGS)
    test: pngtest
    ./pngtest
    install: libpng.a libpng.so.$(PNGVER)
    -@if [ ! -d $(INCPATH) ]; then mkdir $(INCPATH); fi
    -@if [ ! -d $(LIBPATH) ]; then mkdir $(LIBPATH); fi
    cp png.h pngconf.h $(INCPATH)
    chmod 644 $(INCPATH)/png.h $(INCPATH)/pngconf.h
    cp libpng.a libpng.so.$(PNGVER) $(LIBPATH)
    chmod 755 $(LIBPATH)/libpng.so.$(PNGVER)
    -@/bin/rm -f $(LIBPATH)/libpng.so.$(PNGMAJ) $(LIBPATH)/libpng.so
    (cd $(LIBPATH); ln -sf libpng.so.$(PNGVER) libpng.so.$(PNGMAJ);
    ln -sf libpng.so.$(PNGMAJ) libpng.so)
    romfs:
    if [ "$(CONFIG_X86)" = "y" ]; then
    [ -d $(ROMFSDIR)/lib ] || mkdir -p $(ROMFSDIR)/lib ;
    $(ROMFSINST) libpng.so.2 /lib/libpng.so.2 ;
    fi
    clean:
    -/bin/rm -f *.o libpng.so* pngtest pngout.png
    DOCS = ANNOUNCE CHANGES INSTALL KNOWNBUG LICENSE README TODO Y2KINFO
    writelock:
    chmod a-w *.[ch35] $(DOCS) scripts/*
    # DO NOT DELETE THIS LINE -- make depend depends on it.
    png.o png.pic.o: png.h pngconf.h
    pngerror.o pngerror.pic.o: png.h pngconf.h
    pngrio.o pngrio.pic.o: png.h pngconf.h
    pngwio.o pngwio.pic.o: png.h pngconf.h
    pngmem.o pngmem.pic.o: png.h pngconf.h
    pngset.o pngset.pic.o: png.h pngconf.h
    pngget.o pngget.pic.o: png.h pngconf.h
    pngread.o pngread.pic.o: png.h pngconf.h
    pngrtran.o pngrtran.pic.o: png.h pngconf.h
    pngrutil.o pngrutil.pic.o: png.h pngconf.h
    pngtrans.o pngtrans.pic.o: png.h pngconf.h
    pngwrite.o pngwrite.pic.o: png.h pngconf.h
    pngwtran.o pngwtran.pic.o: png.h pngconf.h
    pngwutil.o pngwutil.pic.o: png.h pngconf.h
    pngpread.o pngpread.pic.o: png.h pngconf.h
    pngtest.o: png.h pngconf.h
    What is wrong in it??Pls hlep.
    --leewood
    --- Quote Start ---
    originally posted by leewood@Jul 31 2006, 07:21 PM
    what is wrong in it??pls hlep.
    thanks
    --leewood
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17299)
    --- quote end ---
    --- Quote End ---
    Your all target reads
    try changing it to read
    all: libpng.a
    If the compiler doesn&#39;t understand how to build "shared objects", then it doesn&#39;t make any sense to include the shared object (.so) target.
    Cheers,
    - slacker
