13 years agoProblem with IORD and IOWR instructions
Dear all, I have a qsys system composed of two NIOS that can access a shared memory (data masters are connected to the memory), when I use the instructions IORD and IOWR I don't obtain the r...
13 years ago --- Quote Start --- Are you sure that the address is correct? You can put Signaltap probes on the shared memory's Avalon interface and monitor what the CPUs are doing when trying to access it. --- Quote End --- Yes I'm sure this is the adress specified by qsys (also defined in system.h)
