16 years agoproblem with interrupts
I have tried to make a simple interrupt of a push button and when i registered the ISR it immediately started to execute the ISR like it's an endless loop.:confused: Another thing, what is the...
16 years agoI have an example (it works fine):
# include "test_II.h"# define switches_base 0x00101030# define leds_base 0x00101000# define push_base 0x00101020 // *** Maneja la interrupcion **** static void push_isr(void* context, alt_u32 id){ volatile int *function=(volatile int*) context; *function=IORD_ALTERA_AVALON_PIO_EDGE_CAP(push_base); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(push_base,0); IOWR_ALTERA_AVALON_PIO_IRQ_MASK(push_base,0xF); } //************************************* int main(void) { volatile int function=0; alt_u32 switches; // Activas la interrupcion. IOWR_ALTERA_AVALON_PIO_IRQ_MASK(push_base,0xF); alt_irq_register(PUSH_IRQ,(void*)&function, push_isr); while(1){ switch(function){ case 0x1: switches= IORD_ALTERA_AVALON_PIO_DATA(switches_base); IOWR_ALTERA_AVALON_PIO_DATA(leds_base,switches); function=0; break; default: break; } } return 0; } Maybe it could help you...
