20 years ago
problem with initramfs
hello all friend
i have made kernel image with initramfs.i have used nios ide fot it.
for intramfs ,i have made rootfs sourse with help of nios (filesystem project).
but when i load it on board then i get folowing messeges..
Linux version 2.6.11-uc0 (Administrator@WINWORK_013) (gcc version 3.4.1 (Altera
Nios II 5.0 b73))# 2 Tue Jul 11 14:25:43 IST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6656k/8192k RAM, 0k/0k ROM (749k kernel code, 671k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Kernel panic - not syncing: junk in compressed archive
i know i have to select linux system for building vmlinux not nios ide on window.
but can you help me to build kernel with initramfs on nios ide.
    Jdhar and I had tried a lot on cygwin, but failed. You may track the old posts. Your problem may be in kernel Makefile, there are too many dos2unix.
    I don&#39;t recommend work on IDE. Actually I think it is totally wrong. But it is all up to you. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    thaks hippo for reply.
    now i am starting with linux redhat-9.
    i have downloaded nios2linux-1.4.zip and build0411.zip.
    but i can&#39;t understand your 3and 4 step in buildrootguide.
    which folder i have to make in ~/download folder. and which source i have to put in which folder.
    please guide me hippo....
    soory hippo
    i get idea how to start.
    but i have some query.
    1> i have linux redhat -9.is it posible on radhat -9?
    2> can i use source uClinux-dist-20060511.tar.bz2 in place of uClinux-dist-
    20051110.tar.bz2.
    please reply as soon as posible.
    --- Quote Start ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16811)
    --- quote end ---
    --- Quote End ---
    the make command in redhat 9.0 may be too old.
    you&#39;d better use Fedora core 5.
    Don&#39;t follow the buildroot guide !!
    The wiki is easier now. follow step 1-3.
    http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux)
    hi hippo
    i have read step1-3 .i have some query.
    according it and my understanding for it,i have made following doc for my reference .before going to work on linux, i want to be sure am i right or wrong .
    can you tell me where i am wong in my doc.
    i am following below step:
    -> i have copy source code into home folder
    ls
    => o/p:
    uClinux-dist-test-20060511.tar.bz2 uClinux-dist.diff.gz nios2gcc.tar.bz2
    nios2libs.tar.bz2 build0411.zip nios2rootfs.tar.bz2 nios2linux-1.4.zip
    -> Login as a user account on Linux PC, open a terminal.
    pwd ->/home
    su -# root passwd
    tar jxf nios2gcc.tar.bz2 -C /
    exit
    ->so now /opt is in home folder.next command for setting path
    ->for /home/opt/nios2/bin
    PATH=$PATH:/home/opt/nios2/bin:$usr/bin
    ->for checking command
    nios2-linux-uclibc-gcc -v
    ->Login as a user account on Linux PC, open a terminal.
    su -# your root passwd
    tar jxf nios2libs.tar.bz2 -C /
    exit
    -> i have query after above step => have i to give PATH for nios2libs ? if
    -> yes, then where? .
    -># login as a user account, don&#39;t use root account,
    cd /home
    tar jxf uClinux-dist-test-20060511.tar.bz2
    cd uClinux-dist-test
    zcat ../uClinux-dist.diff.gz | patch -p0
    -> still in /home/uClinux-dist-test dir, don&#39;t cd linux-2.6.x
    make menuconfig
    make linux_hwselect SYSPTF=your_system.ptf
    make romfs# to create romfs dir, make will fail, ignored
    make menuconfig
    -> compile kernel and apps
    make
    -> rebuild kernel for initramfs
    make linux image
    --- Quote Start ---
    originally posted by slsnios@Jul 13 2006, 02:43 PM
    hi hippo
    eg, i am user hippo,
    -> login as a user account, eg hippo on linux pc, open a terminal.
    -> i have copy source code into /home/hippo folder
    ls /home/hippo
    => o/p:
    uclinux-dist-test-20060511.tar.bz2 uclinux-dist.diff.gz nios2gcc.tar.bz2
    su -# root passwd
    tar jxf /home/hippo/nios2gcc.tar.bz2 -c /
    exit
    ->so /opt/nios2/bin has the cross gcc. next command for setting path
    ->add /opt/nios2/bin to path ( if you save it to .bash_profile, logout and login again)
    path=$path:/opt/nios2/bin
    --> install uclinux-dist source
    cd /home/hippo
    tar jxf uclinux-dist-test-20060511.tar.bz2
    cd uclinux-dist-test
    zcat ../uclinux-dist.diff.gz | patch -p0
    -> still in /home/hippo/uclinux-dist-test dir, don&#39;t cd linux-2.6.x
    make menuconfig
    make linux_hwselect sysptf=path of your_system.ptf
    make menuconfig
    make
    make linux image
    --> the kernel in elf object format will be /home/hippo/uclinux-dist-test/images/zimage
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16853)
    --- quote end ---
    --- Quote End ---
    updated your doc.
    Hi all
    I have Fedora core 3.
    i have succeed up to following step:
    ls
    => o/p:
    nios2libs.tar.bz2
    pwd ->/home/slsnios/
    su -# root passwd
    exit
    PATH=$PATH:/home/slsnios/opt/nios2/bin:$usr/bin
    exit
    cd /home/slsnios/
    -> still in /home/slsnios/uClinux-dist-test dir, don&#39;t cd linux-2.6.x
    make menuconfig
    make menuconfig
    make
    But when i gave make command ,then i got following messages
    make -C tools/ucfront
    make[1]: Entering directory `/home/sls/krunal/initfs/uClinux-dist-test/tools/ucfront&#39;
    make[1]: Nothing to be done for `all&#39;.
    make[1]: Leaving directory `/home/slsnios/uClinux-dist-test/tools/ucfront&#39;
    ln -sf /home/slsnios/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc
    ln -sf /home/slsnios/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++
    ln -sf /home/slsnios/uClinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-ld
    make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-
    2.6.x zImage || exit 1
    /bin/sh: nios2-linux-uclibc-gcc: command not found
    make[1]: nios2-linux-uclibc-gcc: Command not found
    make[1]: Entering directory `/home/slsnios/uClinux-dist-test/linux-2.6.x&#39;
    CHK include/nios2_system.h
    perl -I/home/slsnios/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts /home/slsnios/uClinu
    x-dist-test/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl CPU SDRAM CFI_Flash < /home/slsnios
    /project/ESDK_Board_Diagnostic_System_using_NiosII.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h
    ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39;
    UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
    make[1]: *** [include/nios2_system.h] Interrupt
    make: *** [linux] Interrupt
    [sls@test uClinux-dist-test]$ PATH=$PATH:/home/slsnios/opt/nios2/bin:$/bin
    [sls@test uClinux-dist-test]$ make
    make[1]: Entering directory `/home/slsnios/uClinux-dist-test/tools/ucfront&#39;
    no emulation specific options.
    CHK include/linux/version.h
    CHK include/linux/compile.h
    SKIPPED include/linux/compile.h
    CHK usr/initramfs_list
    Kernel: arch/nios2nommu/boot/zImage is ready
    make[1]: Leaving directory `/home/slsnios/uClinux-dist-test/linux-2.6.x&#39;
    if [ -f linux-2.6.x/vmlinux ]; then
    ln -f linux-2.6.x/vmlinux linux-2.6.x/linux ;
    fi
    . linux-2.6.x/.config; if [ "$CONFIG_MODULES" = "y" ]; then
    [ -d linux-2.6.x/modules ] || mkdir linux-2.6.x/modules;
    C linux-2.6.x modules;
    fi
    for dir in include lib include user ; do [ ! -d $dir ] || make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -
    C $dir || exit 1 ; done
    make[1]: Entering directory `/home/slsnios/uClinux-dist-test/include&#39;
    find . -depth -type l -a ! -name Makefile | xargs rm > /dev/null 2>&1 || exit 0
    find . -depth -type d | xargs rmdir > /dev/null 2>&1 || exit 0
    Making symlinks in include/
    Making include/c++ symlink to compiler c++ includes
    make[1]: Leaving directory `/home/slsnios/uClinux-dist-test/include&#39;
    make[1]: Entering directory `/home/slsnios/uClinux-dist-test/lib&#39;
    for i in ../include uClibc ../include /home/slsnios/uClinux-dist-test/prop ; do
    if [ -d $i ]; then
    touch $i/.sgbuilt_lib;
    make -C $i || exit $? ;
    fi;
    make make_links || exit ;
    done
    touch: cannot touch `../include/.sgbuilt_lib&#39;: Permission denied
    make[2]: Entering directory `/home/slsnios/uClinux-dist-test/include&#39;
    make[2]: Leaving directory `/home/slsnios/uClinux-dist-test/include&#39;
    make[2]: Entering directory `/home/slsnios/uClinux-dist-test/lib&#39;
    Making symlinks in lib/
    make[2]: Leaving directory `/home/slsnios/uClinux-dist-test/lib&#39;
    touch: cannot touch `uClibc/.sgbuilt_lib&#39;: Permission denied
    /bin/sh: nios2-elf-gcc: command not found
    make[2]: Entering directory `/home/slsnios/uClinux-dist-test/uClibc&#39;
    + ./extra/scripts/fix_includes.sh -k &#39;~/uClinux-dist-test/linux-2.6.x&#39; -t nios2 -n
    The file ~/uClinux-dist-test/linux-2.6.x/Makefile or ~/uClinux-dist-test/linux-2.6.x/include/linux/version.h is mis
    sing!
    Perhaps your kernel source is broken?
    make[2]: *** [headers] Error 1
    make[2]: Leaving directory `/home/slsnios/uClinux-dist-test/uClibc&#39;
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/slsnios/uClinux-dist-test/lib&#39;
    make: *** [subdirs] Error 1
    please help me where i am wrong .
    slsnios,
    to pick up the original thread,
    I had the same problem using the IDE, the archive it produces on Cygwin seems to be corrupted. I use the IDE for Kernel developement, but I have also a Linux machine for compiling applications or libraries.
    To bypass the problem of the corrupted archive I create the archive on Linux machine FC4 and include it in the IDE.
    In the file linux-2.6.x\usr\initramfs_data.s you must specify the path where your archive resides. In the kernels menuconfig I picked the same path.
    On the Linux machine you create the initramfs_data.gpio.gz archive and copy it to the directory from where it should be included.
    Whenever you build the kernel in the IDE your archive gets picked instead of the IDEs archive.
    However,
    this method also fails if the archive is bigger than 100k.
    Then a compiler warning like: file truncated
    shows up.
    So in my opinion initramfs only works under Linux
