20 years agoproblem with goahead webserver...
i followed alex's steps to port the webserver. everything seems fine but i cant access the demo webpage. i can ping my de2 but cant access it with web browser. here are some of my questions...
20 years agoAhh... nios forum is finally back online.
i think i'll rearrange my problem here... <div class='quotetop'>QUOTE </div> --- Quote Start --- wgoossens: When you hadn't yet added the goahead web server your rootfs didn't use that much memory so you could still run.[/b] --- Quote End --- before using rootfs, i put my web dir n webs in ~/uClinux-dist-test/romfs and ~/uClinux-dist-test/romfs/bin. it booted ok but after i run the webs cmd, it seems tat nth happen n i cant access anything with browser. <div class='quotetop'>QUOTE </div> --- Quote Start --- hippo: what is the result of goahead with uClinux-dist-test ?[/b] --- Quote End --- does it mean putting my web dir n webs under romfs n romfs/bin as above? <div class='quotetop'>QUOTE </div> --- Quote Start --- hippo: You should try to reduce the initramfs size.[/b] --- Quote End --- how do i do tat? <div class='quotetop'>QUOTE </div> --- Quote Start --- hippo: DE2 has only 8MB sdram.[/b] --- Quote End --- i suppose my problem is not with the 8mb ram as this (http://i74.photobucket.com/albums/i248/jwlam1984/console2.jpg) but with the 1mb flash instead. coz my zImage file is 1.3 or 1.4mb. pls correct me if i'm wrong. is there any method i can reduce the size of zImage? pls guide. thx. ps. i din add any user apps. all r default.
