20 years agoproblem with goahead webserver...
i followed alex's steps to port the webserver. everything seems fine but i cant access the demo webpage. i can ping my de2 but cant access it with web browser. here are some of my questions...
20 years agoFrom mnl_nios2_board_cycloneII_2c35.pdf
<div class='quotetop'>QUOTE </div> --- Quote Start --- - 16 Mbytes of flash memory - 2 Mbytes of synchronous SRAM - 32 Mbytes of double data rate (DDR) SDRAM[/b] --- Quote End --- From DE2_Introduction_box.pdf <div class='quotetop'>QUOTE </div> --- Quote Start --- 8-MB SDRAM, 512-KB SRAM, 4-MB Flash[/b] --- Quote End --- these 2 files come with the CDs (Nios II Embedded System and DE2 System respectively) included in my DE2 package. On the DE2 board i can c it's Cyclone II EP2C35F672C6, so i always tot the 2 files r refering to the same board. obviously it's not but which board is the first one refering to? also, it seems tat all those example designs under C:\altera\kits\nios2_60\examples\verilog\niosII_cycloneII_2c35 r not meant for DE2 bcoz they r using the lan91c111 ethernet chip which doesnt exist on DE2. correct my if i'm wrong. Thx.
