20 years agoproblem with goahead webserver...
i followed alex's steps to port the webserver. everything seems fine but i cant access the demo webpage. i can ping my de2 but cant access it with web browser. here are some of my questions...
20 years ago --- Quote Start --- originally posted by jwlam@Jul 21 2006, 12:25 AM thx for your reply, hippo.
i've done wat u said and made the zimage. i download it to my de2, i can go into the terminal but it show sth like this (http://i74.photobucket.com/albums/i248/jwlam1984/console.jpg) when i run any command. the list keep going on non stop.
any idea wat's going on? pls help. thx again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17046)
--- quote end ---
--- Quote End --- I'm affraid you're out of memory. The message your getting are from the oom-killer (Out Of Memory killer) The DE2 board has not much memory... I'm affraid that board will not run a webserver. You can however if you manage to get the SD-card running and put your rootfs and a swap partition on the SD card so you will get extra memory from losing the rootfs in RAM and the oom-killer will not kick in when there is swap-space available (unless that is full too). One thing to consider: Swap space is VERY slow memory... Your system won't run any faster with it, it will run. That's all. Hope this helps! Edit: He Hippo! We were typing the same info at the same time.... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
