19 years agoProblem with getty
Hi, I try to add a login to uClinux-dist-20060803 patch V32. I've added to busybox adduser/ addgroup / deluser / delgroup / login / su / passwd / getty / shadowpw support. It work...
19 years agoYou should disable the console shell in the simple init.
Core Applications--> [*] init [ ] enable console shell <== The getty in busybox might take more memory. You should try agetty, which is standalone. [*] agetty
