16 years agoProblem with gcc4 toolchain
Hello, i have written following code to demonstrate the issue: # include <stdio.h> int main(void) { unsigned long long int long_val = 0xaaaaaaaaaaaaaaaaLLU; unsigned long vala ...
16 years agoWe are watching this post closely so if you run into similar issues with the compiler upgrade that occurred in 10.0 please post them here and/or file a service request at this location and mention my name "Jarrod" in the description so that I can keep an eye on the issue: https://www.altera.com/myaltera/mal-index.jsp while referencing this post.
If you file a service request please attach your system and software if possible to help us re-create the issue (this always helps any time you file a service request). A minimal set of files is always welcome so if you can re-produce this issue with a minimal set of components in your system that always helps us and if you have any additional information please provide it via notes in the service request. Thank-you, Jarrod - Embedded Applications Altera
