20 years agoProblem with Flash alt_flash_open_dev()
Problems with: alt_flash_open_dev() I am running the memtest.c program that Altera provides with the Nios II IDE. It runs as expected when testing RAM but I have problems when testing Flash....
20 years ago --- Quote Start --- originally posted by niosiiuser@Jan 8 2006, 05:15 AM hello jim,
are you using the flash in 8 bit mode? if yes take a look at: http://forum.niosforum.com/forum/index.php?showtopic=455 (http://forum.niosforum.com/forum/index.php?showtopic=455)
regards,
niosiiuser
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12042)
--- quote end ---
--- Quote End --- Hi niosIIuser, I am using a 16 bit Flash. In SOPC Builder, for the CFI Flash Memory Device I selected: AMD29LV128M (WORD Mode) Add Width: 23 bits, Data Width: 16 bits I looked at the Post you referenced and it made me question how I connected the Address lines. I shifted the Address lines by 1, that is address bit 1 from the ext_flash_bridge_address is connected to my Flash Device Address bit 0. Thanks for the reply. Jim
