21 years agoProblem with first run
This is a newbie question. Installation and upload of the kernel and file system went smoothly on my 1s10 development board. Howerever first connection via terminal with the uClinux failed with...
21 years agoanother problem now http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
<div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. On node 0 totalpages: 4096 DMA zone: 0 pages, LIFO batch:1 Normal zone: 4096 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: root=/dev/hda1 PID hash table entries: 16 (order 4: 128 bytes) Memory available: 14788k/4096k RAM, 0k/0k ROM (1134k kernel code, 259k data) Calibrating delay loop... 24.72 BogoMIPS Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) POSIX conformance testing by UNIFIX NET: Registered protocol family 16 Serial: JTAG UART driver $Revision: 1.3 $ ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 50000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07: ed:ff:8c:ab smc_probe: 50000 Khz Nios Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=1 hda: CF 16MB, CFA DISK drive hdb: no response (status = 0xff), resetting drive hdb: no response (status = 0xff) Using anticipatory io scheduler ide0 at 0x80900800-0x80900807,0x80900838 on irq 8 microtronix[mtd]: RAM probe address=0x200000 size=0x538000 Creating 1 MTD partitions on "RAM": 0x00000000-0x00538000 : "ROMfs" microtronix[mtd]: set ROMfs to be root filesystem NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) NET: Registered protocol family 1 NET: Registered protocol family 17 VFS: Cannot open root device "hda1" or unknown-block(0,0) Please append a correct "root=" boot option Kernel panic: VFS: Unable to mount root fs on unknown-block(0,0)[/b] --- Quote End --- what is that? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
