21 years agoProblem with first run
This is a newbie question. Installation and upload of the kernel and file system went smoothly on my 1s10 development board. Howerever first connection via terminal with the uClinux failed with...
21 years ago --- Quote Start --- originally posted by ken@Nov 30 2004, 11:12 AM looking at the kernel commandline, i noticed that you passed:
root=/dev/hda rw
/dev/hda represents the entire disk/drive. what you want is to specify a partition. in your case, that would be the first partition.
so your kernel command line should read:
root=/dev/hda1 rw
give that a try... i think that should solve the problem. --- Quote End --- another error: <div class='quotetop'>QUOTE </div> --- Quote Start --- On node 0 totalpages: 4096 DMA zone: 0 pages, LIFO batch:1 Normal zone: 4096 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: root=/dev/hda1 rw PID hash table entries: 16 (order 4: 128 bytes) Memory available: 14480k/4096k RAM, 0k/0k ROM (1394k kernel code, 306k data) Calibrating delay loop... 24.78 BogoMIPS Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) POSIX conformance testing by UNIFIX NET: Registered protocol family 16 Serial: JTAG UART driver $Revision: 1.3 $ ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 50000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07: ed:00:00:00 smc_probe: 50000 Khz Nios Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=1 hda: CF 16MB, CFA DISK drive hdb: no response (status = 0xff), resetting drive hdb: no response (status = 0xff) Using anticipatory io scheduler ide0 at 0x80900800-0x80900807,0x80900838 on irq 8 hda: max request size: 128KiB hda: 31232 sectors (15 MB) w/1KiB Cache, CHS=61/16/32 hda: hda1 microtronix[mtd]: RAM probe address=0x200000 size=0x538000 Creating 1 MTD partitions on "RAM": 0x00000000-0x00538000 : "ROMfs" microtronix[mtd]: set ROMfs to be root filesystem NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) NET: Registered protocol family 1 NET: Registered protocol family 17 hda: hda1 hda: hda1 hda: hda1 Kernel panic: VFS: Unable to mount root fs on hda1[/b] --- Quote End --- the cf is formatted with ext2fs.hda1 has bootable primary partition,as the quick guide suggest. what is the way? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
