21 years agoProblem with first run
This is a newbie question. Installation and upload of the kernel and file system went smoothly on my 1s10 development board. Howerever first connection via terminal with the uClinux failed with...
21 years agoLooking at the kernel commandline, I noticed that you passed:
root=/dev/hda rw /dev/hda represents the entire disk/drive. What you want is to specify a partition. In your case, that would be the first partition. So your kernel command line should read: root=/dev/hda1 rw Give that a try... I think that should solve the problem.
