15 years agoProblem with ethernet speed
Hi, I have cyclone III with the default niosII plate form of quartus 9.0. I use the triple speed ethernet ip. When i want to run the simple socket server program. I work only at 10Mbps, im...
15 years agoHi Polm,
Ok, if you're using the Dev. kit, is it safe to assume that you're also using one of the examples (particularly the hardware/FPGA design) that came with it? If so, then things certainly should work. Try stepping through ethernet init to make sure that autoneg is being set properly...? Browse the knowledge base, look through the forum some more and, if all else fails, file an SR with Altera. Cheers, -- slacker
