15 years agoProblem with ethernet speed
Hi, I have cyclone III with the default niosII plate form of quartus 9.0. I use the triple speed ethernet ip. When i want to run the simple socket server program. I work only at 10Mbps, im...
15 years agoI use a cyclone 3 devkit
The ethernet transeiver one the board is an alaska_gigabit_ethernet_transceivers I use a cross network cable to link the pc an the altera. I also try with a router, same result.
