15 years agoProblem with ethernet speed
Hi, I have cyclone III with the default niosII plate form of quartus 9.0. I use the triple speed ethernet ip. When i want to run the simple socket server program. I work only at 10Mbps, im...
15 years agoPlease let us know the PHY you're using and how you've set it up. If it's an Altera (or Terasic or some other partner) Dev. Kit then please provide that info too.
Cheers, -- slacker
