21 years agoProblem with eCos stack and data corruption
Hi! I've been fooling with stack and data corruption for a long time. Now I've decided to run the eCos tests, and I've seen that some of them don't work, and I've fou...
21 years agoI've looked at the mallocs, and the test only calls malloc one time. The program counts the times malloc fails, and I have added a check in order to see if malloc returns null.
The result is that my check doesn't appars (it seems that all mallocs succeed), and the tracing of the test is: " State dump 1 (0 hours, 1 minutes) [numbers >>0] Handler-invocations: 3 3 2 2 2 1 1 1 1 1 0 0 0 0 0 0 0 0 0 malloc()-tries/failures: -- 1700 0 client_makes_request: 0 Memory system: Total=0x000b9e60 Free=0x000b9c40 Max=0x000b9c34 Stack usage: Interrupt : Interrupt stack used 4096 size 4096 Idle : Idlethread stack used 440 size 2048 Main : stack used 1140 size 5688 Handler : stack used 2616 size 7128 Handler : stack used 2616 size 7128 Handler : stack used 2680 size 7128 Handler : stack used 2688 size 7128 Handler : stack used 2664 size 7128 Handler : stack used 2616 size 7128 Handler : stack used 2692 size 7128 Handler : stack used 2616 size 7128 Handler : stack used 2680 size 7128 Handler : stack used 2688 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Listener : stack used 1120 size 5688 Listener : stack used 1048 size 5688 Listener : stack used 1080 size 5688 Listener : stack used 900 size 5688 Client : stack used 344 size 5688 Client : stack used 368 size 5688 Client : stack used 300 size 5688 Client : stack used 292 size 5688 State dump 2 (0 hours, 2 minutes) [numbers >>0] Handler-invocations: 47 40 36 29 23 16 13 12 9 8 2 1 0 0 0 0 0 0 0 malloc()-tries/failures: -- 23588 0 client_makes_request: 0 Memory system: Total=0x000b9e60 Free=0x000b9c40 Max=0x000b9c34 Stack usage: Interrupt : Interrupt stack used 4096 size 4096 Idle : Idlethread stack used 440 size 2048 Main : stack used 1140 size 5688 Handler : stack used 2688 size 7128 Handler : stack used 2712 size 7128 Handler : stack used 2688 size 7128 Handler : stack used 2712 size 7128 Handler : stack used 2688 size 7128 Handler : stack used 2696 size 7128 Handler : stack used 2692 size 7128 Handler : stack used 2688 size 7128 Handler : stack used 2692 size 7128 Handler : stack used 2696 size 7128 Handler : stack used 2664 size 7128 Handler : stack used 2632 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Handler : stack used 0 size 7128 Listener : stack used 1160 size 5688 Listener : stack used 1152 size 5688 Listener : stack used 1136 size 5688 Listener : stack used 1152 size 5688 Client : stack used 376 size 5688 Client : stack used 368 size 5688 Client : stack used 400 size 5688 Client : stack used 436 size 5688 " So it seems that there's still 0x000b9c34 memory free, so ... I am working on trying the test on the Evaluation board with all the modules, included the SDRAM... Alex
