21 years agoProblem with eCos stack and data corruption
Hi! I've been fooling with stack and data corruption for a long time. Now I've decided to run the eCos tests, and I've seen that some of them don't work, and I've fou...
21 years agoI usually also test in hardware, but as the tests didn't korked, I tried to do it in the ISS simulator, in order to see if the problem was software or hardware.
The fact is that if I run it in the evaluation board (now I can), all the tests (that didn't worked before) work except "stress_threads". If I debug it, it runs until "main", and then continues. When I stop it, the value of PC is 0x10000 (more or less), which is not a valid address for executing code, isn't it? Obviously, the program doesn't works I've seen also that sometimes the console shows "Bad byte in chunk". NOW. I have activated xxx_STACK_CHECKING, and also CYGPKG_INFRA_DEBUG, because the previous option needs asserts activated. Now, when I run the "stress_threads", it says " ASSERT FAIL: <1>stream.cxx[585]Cyg_ErrNo Cyg_StdioStream::write() Stream object is not a valid stream! ASSERT FAIL: <1>stream.cxx [ 585] Cyg_ErrNo Cyg_StdioStream::write() " I have seen asserts like these many times while running my code. Asserts that, if a line of code is added (e.g. a printf) , disappear (sometimes, not always). I thought it was some part of my code that was wrong, but looking at this, I think there's another problem. Notice that this assert is happennig before "main", because I have the debugger configured to stop when the program user starts, and the asserts appears before that. Any idea? Alex
