21 years agoProblem with DMA in new NIOS
Hello! I've made design for my custom board and I run it does work, but when I added to my design DMA it doesn't work. Then I remove dma from design it again does work. In old ...
21 years agoCamelot, since you never mentioned bursting, I'll assume your DMA is not burst-enabled. (From what you've said about your system, you'd get no advantage from enabling DMA bursts.)
Your program runs, so you've managed to avoid the problem mentioned in SPR 176819. Question: is your DMA write master connected to your VGA component (vga) in SOPC Builder?
