19 years agoproblem with dm9000a
Hello everyone: I want to enable network of uClinux on my custom board, but there seems to be some problem.. 1, I can't see the "<DM9000x> I/O: 80900090, VID: 90000a46 and eth0" messag...
19 years agogunzip uClinux-dist-20060803-nios2-02.diff.gz
you will get uClinux-dist-20060803-nios2-02.diff edit this file, and you can find dm9ks stuff. note you need to update arch/nios2nommu/setup.c, drvers/next/ Spcae.c, Makefile and Kconfig. But I wonder there are problems in your hardware, so you should try to add some debug messages and dump in the old dm9000x.c . Using a new driver won't work on a bad hardware. And the link to uClinux-dist-20070130, http://s4.quicksharing.com/v/2589078/uclin...30.tar.bz2.html (http://s4.quicksharing.com/v/2589078/uclinux_dist_20070130.tar.bz2.html)
