21 years agoProblem with debugging assembly code with NIOS II
I have an assembly file that looks like the following:
#include "nios2.h"# include "system.h"# include "cpu_const.h"
.extern tmp_space
.section .text
1 .global _cpu_task_start
2 _cpu_task_start:
3 movia r22, tmp_space
4 movia r23, REGISTERS_OFFSET
5 _cpu_task_loop:
6 ldbio r21,status_offset(r23)
7 andi r2,r21,status_rec_bit
8 beq r2,r0, koniec_rec
and so on And I have c code witch calls this function 9 _cpu_task_start(); Everything compiling and linking ok. It seems to work ok too. But if I try to debug it with NIOS II IDE, I can't debug assembly function. When debugger stops on line 9, debugging work fine, I see source code window and disassembly window. When I try to do “Step Into” debugger stops at the first line, but I can see it only on disassembly window, the source code window still remain on line 9 <div class='quotetop'>QUOTE </div> --- Quote Start --- Disassembly window 0x01000594 <_cpu_task_start>: movhi r22,257 0x01000598 <_cpu_task_start+4>: addi r22,r22,11376 0x0100059c <_cpu_task_start+8>: movhi r23,160 0x010005a0 <_cpu_task_start+12>: addi r23,r23,512[/b] --- Quote End --- In this way, I only can debug first two line of assembly code, line no. 6 is unreachable. (Debugger dont stop, if I suspend, it stops in C code, much more ahead). If I set a breakpoint in line 7, the debugger stops in entirely different function “alt_irq_init”. It seems for me, that debugger doesn't see my test.s file. Pleas help, what can I do to debug it in normal way. The assembly part of start up code is debugging fine. I'll be appreciate for any advice. I use NIOS V5.0. Regards DarekNo RepliesBe the first to reply
