16 years agoproblem with custom board
Hello everybody!
I try out to run Linux with MMU on a custom board with EP3C25 Cyclone III FPGA. (interrupt vector is in sdram, irq 0 is set to sys_clk_timer) I successfully started a simple "hello world" in niosII eds with my sopc configuration (without mmu) without any problems. Then I followed the description on nioswiki.com to create a linux image (Linux for NiosII Processor with mmu). I changed nios.h/config.c to fix compiler errors (using defines of custom_fpga.h). But after downloading the image to external sdram and starting terminal I always get the following error message: [NiosII EDS]$ nios2-download -g zImage.initramfs.gz Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 2890KB in 49.6s (58.2KB/s) Verified OK Starting processor at address 0xC0D00000 /cygdrive/c/Data/Transfer [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.30-00512-g81d0c3c-dirty (vadmin@vadmin) (gcc version 4.1.2)# 1 68 Mon Apr 12 01:08:45 EDT 2010 console [early0] enabled Early printk initialized Linux/Nios II-MMU init_bootmem_node(?,0xb99, 0x800, 0x1000) free_bootmem(0xb99000, 0x467000) reserve_bootmem(0xb99000, 0x100) Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032 Kernel command line: NR_IRQS:32 PID hash table entries: 32 (order: 5, 128 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) We have 4096 pages of RAM Memory available: 4424k/3681k RAM, 0k/0k ROM (1017k kernel code, 2663k data) Calibrating delay loop... 11.87 BogoMIPS (lpj=59392) Mount-cache hash table entries: 512 init_BSP(): registering device resources Kernel panic - not syncing: Out of memory and no killable processes... Have i missed anything?No RepliesBe the first to reply
