16 years agoProblem with compiling hello.c
Hi everyone, I've got a small problem regarding compiling the hello.c like it was said in the wiki (http://www.nioswiki.com/installnios2linux). There was no problem doing the stuff before. I us...
16 years agothx for the reply.
yeah i already to change some of the data... but the specs, its asm and if there is something to change i even don't know what i should change :) specs:*asm:
%{!EB:%{!meb:-EL}} %{EB|meb:-EB}
*asm_debug:
*asm_final:
*asm_options:
%a %Y %{c:%W{o*}%{!o*:-o %w%b%O}}%{!c:-o %d%w%u%O}
*invoke_as:
%{!S:-o %|.s |
as %(asm_options) %m.s %A }
*cpp:
*cpp_options:
%(cpp_unique_options) %1 %{m*} %{std*&ansi&trigraphs} %{W*&pedantic*} %{w} %{f*} %{g*:%{!g0:%{!fno-working-directory:-fworking-directory}}} %{O*} %{undef}
*cpp_debug_options:
%{d*}
*cpp_unique_options:
%{C|CC:%{!E:%eGCC does not support -C or -CC without -E}} %{!Q:-quiet} %{nostdinc*} %{C} %{CC} %{v} %{I*} %{P} %I %{MD:-MD %{!o:%b.d}%{o*:%.d%*}} %{MMD:-MMD %{!o:%b.d}%{o*:%.d%*}} %{M} %{MM} %{MF*} %{MG} %{MP} %{MQ*} %{MT*} %{!E:%{!M:%{!MM:%{MD|MMD:%{o*:-MQ %*}}}}} %{remap} %{g3:-dD} %{H} %C %{D*&U*&A*} %{i*} %Z %i %{E|M|MM:%W{o*}}
*trad_capable_cpp:
cc1 -E %{traditional|ftraditional|traditional-cpp:-traditional-cpp}
*cc1:
%{G*} %{EB:-meb} %{EL:-mel} %{EB:%{EL:%emay not use both -EB and -EL}}
*cc1_options:
%{pg:%{fomit-frame-pointer:%e-pg and -fomit-frame-pointer are incompatible}} %1 %{!Q:-quiet} -dumpbase %B %{d*} %{m*} %{a*} %{c|S:%{o*:-auxbase-strip %*}%{!o*:-auxbase %b}}%{!c:%{!S:-auxbase %b}} %{g*} %{O*} %{W*&pedantic*} %{w} %{std*&ansi&trigraphs} %{v:-version} %{pg:-p} %{p} %{f*} %{undef} %{Qn:-fno-ident} %{--help:--help} %{--target-help:--target-help} %{!fsyntax-only:%{S:%W{o*}%{!o*:-o %b.s}}} %{fsyntax-only:-o %j} %{-param*}
*cc1plus:
*link_gcc_c_sequence:
%G %L %G
*endfile:
crtend%O%s crtn%O%s
*link:
*lib:
--start-group %{msmallc: -lsmallc} %{!msmallc: -lc} -lgcc %{msys-lib=*: -l%*} %{!msys-lib=*: -lc} --end-group %{msys-lib=: %eYou need a library name for -msys-lib=}
*libgcc:
-lgcc
*startfile:
%{msys-crt0=*: %*} %{!msys-crt0=*: crt1%O%s} %{msys-crt0=: %eYou need a C startup file for -msys-crt0=} crti%O%s crtbegin%O%s
*switches_need_spaces:
*cross_compile:
1
*version:
3.4.6
*multilib:
. !mno-hw-mul !mhw-mulx !mstack-check !mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mno-hw-mul mno-hw-mul !mhw-mulx !mstack-check !mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mhw-mulx !mno-hw-mul mhw-mulx !mstack-check !mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mstack-check !mno-hw-mul !mhw-mulx mstack-check !mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mcustom-fpu-cfg=60-1 !mno-hw-mul !mhw-mulx !mstack-check mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mcustom-fpu-cfg=60-2 !mno-hw-mul !mhw-mulx !mstack-check !mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-2;mstack-check/mcustom-fpu-cfg=60-1 !mno-hw-mul !mhw-mulx mstack-check mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mstack-check/mcustom-fpu-cfg=60-2 !mno-hw-mul !mhw-mulx mstack-check !mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-2;mhw-mulx/mstack-check !mno-hw-mul mhw-mulx mstack-check !mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mhw-mulx/mcustom-fpu-cfg=60-1 !mno-hw-mul mhw-mulx !mstack-check mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mhw-mulx/mcustom-fpu-cfg=60-2 !mno-hw-mul mhw-mulx !mstack-check !mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-2;mhw-mulx/mstack-check/mcustom-fpu-cfg=60-1 !mno-hw-mul mhw-mulx mstack-check mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mhw-mulx/mstack-check/mcustom-fpu-cfg=60-2 !mno-hw-mul mhw-mulx mstack-check !mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-2;mno-hw-mul/mstack-check mno-hw-mul !mhw-mulx mstack-check !mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mno-hw-mul/mcustom-fpu-cfg=60-1 mno-hw-mul !mhw-mulx !mstack-check mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mno-hw-mul/mcustom-fpu-cfg=60-2 mno-hw-mul !mhw-mulx !mstack-check !mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-2;mno-hw-mul/mstack-check/mcustom-fpu-cfg=60-1 mno-hw-mul !mhw-mulx mstack-check mcustom-fpu-cfg=60-1 !mcustom-fpu-cfg=60-2;mno-hw-mul/mstack-check/mcustom-fpu-cfg=60-2 mno-hw-mul !mhw-mulx mstack-check !mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-2;
*multilib_defaults:
EL
*multilib_extra:
*multilib_matches:
mno-hw-mul mno-hw-mul;mhw-mulx mhw-mulx;mstack-check mstack-check;mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-1;mcustom-fpu-cfg=60-2 mcustom-fpu-cfg=60-2;
*multilib_exclusions:
*multilib_options:
mno-hw-mul mhw-mulx mstack-check mcustom-fpu-cfg=60-1 mcustom-fpu-cfg=60-2
*linker:
collect2
*link_libgcc:
%D
*md_exec_prefix:
*md_startfile_prefix:
*md_startfile_prefix_1:
*startfile_prefix_spec:
*sysroot_suffix_spec:
*sysroot_hdrs_suffix_spec:
*link_command:
%{!fsyntax-only:%{!c:%{!M:%{!MM:%{!E:%{!S: %(linker) %l %{pie:-pie} %X %{o*} %{A} %{d} %{e*} %{m} %{N} %{n} %{r} %{s} %{t} %{u*} %{x} %{z} %{Z} %{!A:%{!nostdlib:%{!nostartfiles:%S}}} %{static:} %{L*} %(link_libgcc) %o %{fprofile-arcs|fprofile-generate:-lgcov} %{!nostdlib:%{!nodefaultlibs:%(link_gcc_c_sequence)}} %{!A:%{!nostdlib:%{!nostartfiles:%E}}} %{T*} }}}}}}
i found also the /home/working/nios2/bin/../lib/gcc/nios2-linux-uclibc/3.4.6/install-tools/mkheaders.conf
SYSTEM_HEADER_DIR="/opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/sys-include"
OTHER_FIXINCLUDES_DIRS=""
FIXPROTO_DEFINES=""
STMP_FIXPROTO=""
STMP_FIXINC="stmp-fixinc"
but even if i change this, nothing happens *g*
