15 years agoproblem with code size"need help"
hello,
I have a problem with code size.. I am running an application to view a 24bit color picture on a 480x272 touch screen, I used a 8 Mbyte SDRAM on DE1 board cycloneII and a scatter gather DMA, the only memory in my system is the SDRAM. so the reset vector is at 0x00 and the exception vector is at 0x20(and i tried others like 0x2000) the problem is that when I include a small picture size like 100x50 pixels every thing is ok, but when I try to include a larger size like 200x100 or full picture 480x272 this message appears: mallocr.c:2150: warning: unable to reach (null) (at 0x0023814c) from the global pointer (at 0x0022addc) because the offset (54128) is out of the allowed range, -32678 to 32767. collect2: ld returned 1 exit status make: *** error 1 what is the problem? I have a 8 MByte sdram and the size 480x272 only needs 0.5MByte??? can you help me please??
