15 years agoproblem with code size"need help"
hello, I have a problem with code size.. I am running an application to view a 24bit color picture on a 480x272 touch screen, I used a 8 Mbyte SDRAM on DE1 board cycloneII and a scatter gather D...
15 years ago --- Quote Start --- I don't ever run the IDE! The IDE will have left the .o file lurking somewhere (probably polluting the directory with your sources). It also installs a copy of objdump somewhere. Everything is actually a lot easier to understand if you don't use an IDE - IDEs try to do everything for you by 'magic' and leave you without any of the knowlege required to find out what has really happened when things go wrong. --- Quote End --- thank you .. but from where should I begin? and how can I fix this problem??
