15 years agoproblem with code size"need help"
hello, I have a problem with code size.. I am running an application to view a 24bit color picture on a 480x272 touch screen, I used a 8 Mbyte SDRAM on DE1 board cycloneII and a scatter gather D...
15 years agoI don't ever run the IDE!
The IDE will have left the .o file lurking somewhere (probably polluting the directory with your sources). It also installs a copy of objdump somewhere. Everything is actually a lot easier to understand if you don't use an IDE - IDEs try to do everything for you by 'magic' and leave you without any of the knowlege required to find out what has really happened when things go wrong.
