15 years agoproblem with code size"need help"
hello, I have a problem with code size.. I am running an application to view a 24bit color picture on a 480x272 touch screen, I used a 8 Mbyte SDRAM on DE1 board cycloneII and a scatter gather D...
15 years ago --- Quote Start --- The linker must be putting your program sections together in an incorrect order. The 'small data' section is used for small data items (be default less than 8 bytes) so that they can be accessed using a signed 16bit offset from the 'global pointer' (gp) register instead of having to load the 32bit address for each access. So it looks as though the linker has put a large data item into the 'small data' section making the section larger than 64k. If do a working link (small image array) and then look at the symbol table and linker map output file (you'll need to persuade the IDE to pass -Map file to ld) you should be able to work out why. --- Quote End --- I will try this but how to persuade the IDE to pass MAP file to id??
